Notification bar not showing right number of files with quick search [Fixed]
Gwenael Q.
Post by Gwenael Q. »
- Browser mode: select a folder with some pictures.
- left bottom of XnviewMP window will display the right number of displayed files
- with quicksearch field, reduce the number of displayed files (search among metedata or filenames)
- left bottom of XnviewMP still displaying the same number of files than before.
XnviewMP should display the real number of displayed files
MP 1.4.0
Thanks for listening
Gwenael Q.
Re: Notification bar not showing right number of files with quick search
Hello. Issue still there with the quick search. No problem with "Filter by".
MP 1.4.3 on win 11
Gwenael Q.
Issue still there with "quick search" and also "rating filtering".
Users need to select an image to get the right number of displayed and selected images in the notification bar. Things work as expected with "Filter by".
Thanks for listening !
1.4.4
Gwenael Q.
Fixed in 1.5
Thanks
