2 things to be fixed PLEASE
1st
when i apply effects on batch convert, i want a window appear for telling me where i want to save the new image
Conclusion... when i apply effects on batch convert, the image is saved in the same folder with name Result, OR... select specific folder, it is NOT the way, when i apply effects on Batch Convert, when i finish, i click on Convert, AND... what i want, it´s a window appear to select where i want to save the image, that´s what i need please, that´s the way should be, please fix it Pierre
so please... i want a window appear for telling me where i want to save the new image... please fix that Pierre
and 2nd
when i crop an image and i want to apply effects on batch convert, it appears the default image and not appear the croped image
i hope you fix them soon please, i usually use those options often, and now i can´t use them because i gotta make a lot of steps and that´s not the way, very tedious, VERY VERY TEDIOUS
i hope you fix them soon Please, Thanks
