1.4.2 - viewer - closing Clean metadata dialog modifies image
XnViewMP 1.4.2 64bits
Windows11 64bit (22H2), display resolution 3840x2160, win scaling 150%
Viewer
2. open any image
3. open Clean metadata dialog (Edit > Clean metadata)
4. close Clean metadata dialog
asterisk will appear before the image name and 'Save changed file' dialog will popup when you try to close this file.
Expected behaviour:
closing Clean metadata dialog does not affect image
Re: 1.4.2 - viewer - closing Clean metadata dialog modifies image
fixed in 1.4.3
