Jpeg2000 Massive Image Conversion
pinchies
Post by pinchies »
Firstly, I LOVE XnConvert, and am SO grateful for your work on this excellent tool.
Context:
I frequently work with very large images at my work, using a microscope with the Olympus Stream software. I generally choose to export as JPEG2000 as this format is the best for lossless image compression, support for HUGE images, and good software interoperability... usually. Unfortunately the software engine exports all JPEG2000 as a single full-res "tile", rather than a grid of smaller tiles as most other JP2 libraries do. I have had a massive headache of a time trying to work with these monolithic JP2 files, especially for very very large resolution files.
Problem:
  • Often (30-60% of the time) these massive JP2 files will crash XnConvert when trying to add a file to the queue, or, they often have an error when trying to export/process.
  • I have attached one of the problematic files here.
  • If you are able to fix this, I would be very grateful! I suspect the issue is due to a bug in the internal JP2 decoder used.
Additional info:
  • I did have very good success converting these files using the "OpenJPEG" library directly via commandline.
  • I still had problems with some files when using "ImageMagik" via commandline (which apparently also uses the OpenJPEG engine internally?)
  • Kakadu JPEG2000 software handles it fine but that is $$$$$$ software.
  • I didn't try the much vaunted Grok JPEG2000 library, but that is another alternative open source library, and they claim very high performance.
  • I have 128GB of RAM on my PC.
  • I used XnConvert mostly for personal use previously. However, I just bought an XnConvert license, as if this issue is fixed, I would love to use this heavily for my work too ♥
pinchies
Re: Jpeg2000 Massive Image Conversion
Post by pinchies »
Hello, just wondering if: (1) the problem converting the provided file could be reproduced, and (2) if a fix may be possible? Thank you.
pinchies
Post by pinchies »
Thank you, I was successfully able to open all my massive JP2 files in the new XnView. Is it possible to get an updated XnConvert as well? Kind regards.
pinchies wrote: Wed Mar 01, 2023 4:33 am Thank you, I was successfully able to open all my massive JP2 files in the new XnView. Is it possible to get an updated XnConvert as well? Kind regards.
yes XnConvert will be soon updated
