1.4.3 - batch convert - Blurred frame has constant effect
XnView MP 1.4.3 64bits
Windows11 64bit (22H2), display resolution 3840x2160, win scaling 150%
Batch convert
Blurred frame
Issue
Square option has constant blur effect that does not depend on Blur slider with test image.
test_img_blurred_frame.zip
(60.04 KiB) Downloaded 227 times
Re: 1.4.3 - batch convert - Blurred frame has constant effect
fixed in 1.4.4
