Iptc4xmpCore:Location in XMP editor
dennys
Post by dennys »
I use Tools -> Metadata -> edit IPTS to add the Location. After that, I find "Iptc4xmpCore:Location" of XMP has the same value.
But when I use Tools -> Metadata -> edit XMP, I cannot find it in all tabs.
Is it possible (or should it) to add the tag in XMP editor?
Re: Iptc4xmpCore:Location in XMP editor
Post by michel038 »
Right, I confirm that this XMP field, which can be written with "Edit IPTC" is not accessible with "Edit XMP".
An ugly workaround is to use "only xmp" mode with the "Edit IPTC" dialog :mrgreen:
Post by michel038 »
- Select a (jpg) picture
- Use "Edit IPTC" with Mode = IPTC+XMP
- Enter City, Location, State, Country ... Write
Loc 2.png (7.8 KiB) Viewed 1856 times
Use "Edit XMP"
- City, State, Country are displayed in "Origin" tab, but Location is still not shown ...
dennys
Post by dennys »
xnview wrote: Tue Apr 18, 2023 2:51 pm This problem is supposed to be fixed in XnView MP 1.4.4. Please check and confirm the bug fix here.
My test result is the same as michel038, City, State, and Country are displayed in the "Origin" tab, but Location is still not shown.
And "IPTC extensions" tab (in "edit XMP") also has Location, City, State, and Country, but they are all empty.
Btw, both "Origin" and "IPTC extensions" have the same fields (Location, City, State, and Country), are they read/write the same fields?
issue reopened
This problem is supposed to be fixed in XnView MP 1.4.5. Please check and confirm the bug fix here.
dennys
Post by dennys »
In the "Origin" tab, City, State, Country, and "Location" are all displayed, thanks.
Btw, "IPTC extensions" tab (in "edit XMP") also has Location, City, State, and Country, but they are all empty.
Are these fields the same as "Origin" tab?
dennys wrote: Thu May 11, 2023 1:58 am Btw, "IPTC extensions" tab (in "edit XMP") also has Location, City, State, and Country, but they are all empty.
It's not the same fields
dennys
Post by dennys »
Got it, and thank you to build this amazing software!!
