To copy a picture into PowerPoint, you can right-click on the image, choose "Copy image," and then paste it directly into the PowerPoint slide using Ctrl + V. If you're browsing an image and pressing Ctrl + C, it's probably copying the path instead of the image itself, which is why it pastes the file location. Another way is to save the image first (right-click > Save image as), then drag and drop the saved file into PowerPoint, or use the "Insert" tab to add the picture from your computer.
Also, if you're looking for a good Microsoft Office subscription at a reasonable price, you can click here and acces this site.
How to copy the picture to powerpoint?
