B2 : Diaporamas in .sld-files are always randomly played.
Locked
Post by Guest »
Diaporamas in .sld-files are always randomly played, even if RandomOrder=0.
Grasyop
Re: B2 : Diaporamas in .sld-files are always randomly played
Anonymous wrote:Diaporamas in .sld-files are always randomly played, even if RandomOrder=0.
Strange i have not this problem, you play the sld by clicking on it?
Xyzzy
Post by Xyzzy »
No confirmation in b3 for slide show run from Browser.
X.
marsh
Post by marsh »
Confirmed. SLD file launched from ms explorer uses Xnview's random setting which overrides SLD's setting.
marsh wrote:Confirmed. SLD file launched from ms explorer uses Xnview's random setting which overrides SLD's setting.
Could you send me your .sld and your .ini?
marsh
Post by marsh »
Sent.
When settings are different, then program setting is used instead of SLD setting.
Ex:
SLD uses RandomOrder = 0
Xnview ini uses:
[Slide]
Random=1
marsh
Post by marsh »
Its fixed for me in RC2.
Locked
