1.4.3 - viewer - High zoom quality + HiDPI - extra space on zoom
XnViewMP 1.4.3 64bit
Windows11 64bit (22H2), display resolution 3840x2160, win scaling 150%
Viewer
Image renders with extra space on HiDPI zoom-in (any filter except Bilinear) when zoom level >= windows scale.
In case of 32bit image extra space shows as alpha, otherwhise just a blank space.
0. set win scale >100%, eg 150% in my case
Issue
2. open test image
100x100_rgb.zip
(336 Bytes) Downloaded 202 times
3. press f12 to open Settings
- set 'High zoom quality' to Zoom-in and set any filter except Bilinear
- tick 'Zoom on HiDPI..' checkbox
- press OK
4. increase zoom level >= win scale
image will be rendered with extra space
Related
Re: 1.4.3 - viewer - extra space on HiDPI zoom
Re: 1.4.3 - viewer - High zoom quality + HiDPI - extra space on zoom
fixed in 150
