1.4.3 - viewer - strange file size on Save after Save as
XnViewMP 1.4.3 64bit
Windows11 64bit (22H2), display resolution 3840x2160, win scaling 150%
Viewer
2. open any picture (eg attached one)
png.zip
(131.75 KiB) Downloaded 233 times
3. press CTRL+SHIFT+S to Save as jpg_1.jpg (default format options)
5. press CTRL+S in xnview
file size changes from 54KB to 150KB
6. close xnview
8. press CTRL+S
file size changes from 54KB to 58KB (expected fluctuation)
Few examples saving with other formats (default settings):
        step3    step5    step8
avif    379      141      165
bmp     246      141      246
heic    164      141      164
jpg      54      150       58
jxl     138      141      138
jxr     148      141      147
tiff    247      141      247
xebp     50      141       48
What happes on step3 that affects file size so much?
I would expect 'Save as' produce the same result as Save on step8 (with minor fluctuation if lossy settings).
Re: 1.4.3 - viewer - strange file size on Save after Save as
the output file is PNG not JPEG
fixed in 1.4.4
