1.4.3 - viewer - copy-pasting 4-8bit images is corrupted
XnViewMP 1.4.3 64bit
Viewer
Issue A
2. open test image (4bit, 8colors, 1transparent index)
test_img_A.zip
(32.35 KiB) Downloaded 148 times
3. make any selection
4. press CTRL+C, CTRL+V
- pasted data will be corrupted (as result colors quantity increased to 16)
- image will turns into 32bit
XnView Classic also pastes black data, but if saved and reopened - there is no issue, bitness preserved, pasting only messes if selection area differs (which is understandable).
Issue B
2. open test image (8bit, 256colors)
test_img_B.zip
(149.32 KiB) Downloaded 154 times
- pasted data will be corrupted (as result colors quantity increased to 461)
No such issue is XnView Classic, image preservs same bitness, pasting only messes if selection area differs (which is understandable).
Re: 1.4.3 - viewer - copy-pasting 4-8bit images is corrupted
:bugconfirmed: Thanks to your detailed description I can reproduce "pasted data will be corrupted"
When you paste, image is always converted to 24/32bits.
(In Classic there is some issues when pasting 24bits or different colormap image, so in MP image is always converted in 24/32bits)
fixed in 1.5.0
