1.4.4 - batch convert - avif saves as heic
XnViewMP 1.4.4 64bit
Batch convert
avif saves as heic
2. open test image
test_img_avif.zip
(109.46 KiB) Downloaded 246 times
3. press CTRL+U to open Batch convert
default format settings 'Same as original'
4. press Convert button
file will be saved in .heic format instead of .avif
ps: .jfif saves as .jpg, but I see no issue here, as there is no option to save into .jfif
Related
masterjp
Re: 1.4.4 - batch convert - avif saves as heic
Post by masterjp »
Crazy bug, but I can confirm it.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
This problem is supposed to be fixed in XnView MP 1.4.5. Please check and confirm the bug fix here.
fixed in 1.4.5
