1.4.5 - draw - text - text jumps bottom-right on cursor move
XnViewMP 1.4.5 64bit
Draw - text
1. open any image in Draw
2. select 'Add text' tool
- add some text
- click on image to place text and hold mouse button
issue A
center of cursor does not match red dashed selection rectangular
issue B
3. move mouse in any direction (blue arrow)
text will jump from its original position to bottom-right direction
Related
Re: 1.4.5 - draw - text - text jumps bottom-right on cursor move
1.5.0b1
A - still remain, but I think its not a bug
B - fixed, but there are related issues below
2. open any image in Draw
3. select Text tool
4. click ~30 times while moving cursor over image (in order to insert default text multiple times)
issue C
- sometimes (1 out of 5) text still appears in top-left corner for a split of the second
issue D1
5. close Draw dialog
app will crash
issue D2
5. click Undo button to remove all Text
- all text will be removed
- toolbar: selection will move from Text tool to Selection Tool
6. click on image (toolbar: Selection is selected)
- toolbar: Text tool will be selected
- text will be pasted
app will crash
user0 wrote: Sat Jun 17, 2023 12:34 pm A - still remain, but I think its not a bug
right not a bug, the move point is top left not center
issue C
Right, will be fixed in b2
issue D1
app will crash
issue D2
yes it's normal behavior.
app will crash
I don't understand how to reproduce?
xnview wrote: Mon Jun 19, 2023 11:42 am
issue D2
its OK that focus jumps to Selection tool when you Undo till the start,
its not OK that when you click on image - Text tool will be activated and text will be pasted
Selection tool shall be active one
Another related issue:
- add 3 lines (it can be any tool)
- press Undo once
toolbar: focus will move from Line to Selection Tool
- click on image
Line tool will be activated and line pasted on image
its a bug because if you press Redo - Line tool will be activated,
that means app remembers selected tool at each step, and there is no reason to shift focus to Selection while doing Undo
app will crash
its like this:
3. select Text tool
5. click Undo button until all Text is removed
6. click on image
app will crash
user0 wrote: Mon Jun 19, 2023 2:21 pm its OK that focus jumps to Selection tool when you Undo till the start,
ok i understand now
all fixed in 1.5.0b2
