1.4.5 - crop panel - selection size indicator floats around
XnViewMP 1.4.5 64bit
Viewer - crop panel
selection size indicator floats around when dragging rotated selection
2. open any picture
3. press SHIFT+X to open crop panel
4. make any selection
5. rotate selection (eg to 180deg [upside down])
Issue A
6. resize selection
selection size indicator does not stick to the corner, and will move into opposite direction instead
Issue B
6. drag around this selection
selection size indicator does not stick to the corner, and will float around instead
Related
Re: 1.4.5 - crop panel - selection size indicator floats around
With scaling 100%, same problem?
yep, same issue with 100% win scale
fixed in 1.5.0b1
