1.4.5 - batch convert - crash - closing dialog with only files added via shortcut
XnViewMP 1.4.5 64bit
Batch convert
crash after closing dialog with files added via shortcut (1 action required)
0. have shortcut to test folder with some images
2. open any image
3. press CTRL+U to open Batch convert
4. delete any image on Input tab
5. add any action
6. drag shortcut from windows explorer into Input tab
files* will be added
7. close Batch convert dialog
app will crash
crash_dump.zip
* NOTE: when adding files via dragging:
- folder - files from subfolders will be added
- shortcut - no files from subfolders will be added
Related
Re: 1.4.5 - batch convert - crash - closing dialog with only files added via shortcut
you can reproduce each time?
yep, 100% reproducibility
fixed in 1.5.0b1
but require some tuning for consistancy
  • current behaviour
    • batch convert
      drag&drop only works in whole dialog except file list area
    • join images, slideshow, contact list
      drag&drop only works in file list area
  • expected behaviour
    • all dialogs with file list functionlity
      drag&drop shall work in whole dialog, just drag&drop files on any place/tab/control within dialog (for convinience purpose)
ps. no need to keep notice: "You can drag&drop your files on the list below." as this is obvious standard behaviour
user0 wrote: Fri Jun 16, 2023 6:58 pm
  • batch convert
A new bug, will be fixed in b2
[/list]
A separate post please
right
fixed in 1.5.0b2
xnview wrote: Mon Jun 19, 2023 6:53 am A separate post please
App UI - File list - unify behaviour
