Browser - fix Tooltip
XnViewMP 1.4.5 64bit
Browser - tooltip
- string wrapping sould not be avoided
- Kib shall be KiB
Suggestion A
change Tooltip
  • file
    from
    <b>{Filename}</b><br>{Modified Date} - {EXIF:Date taken}<br>{Size KB} Kib
    to
    <b>{Filename}</b><br>{Modified Date}<br>{EXIF:Date taken}<br>{Size KB} KiB
  • folder / non-image files
Related
Re: Browser - fix Tooltip
This problem is supposed to be fixed in XnView MP 1.5.1. Please check and confirm the bug fix here.
issue remains for File
even with a fresh xnview.ini?
yes
ps. i never use old settings, just delete whole folder and unzip new one :D
right, issue reopened
This problem is supposed to be fixed in XnView MP 1.5.2. Please check and confirm the bug fix here.
fixed, but what about Kib?
- if its kibibyte there shall be capital letter in the end - KiB
- if its kilobyte - just KB
also, there is consistancy issue:
- in Browser tooltip - {Size KB} Kib
- in Viewer Info - {Size KB} KB
right
This problem is supposed to be fixed in XnView MP 1.5.3. Please check and confirm the bug fix here.
fixed in 1.5.3
