1.5.0b1-2 crop+image treatments
simon
Post by simon »
A bug which appears in 1.5.0 (b1 and b2, not present in 1.4.5) is as follows (on windows 10 64 bits)
1) If the image is cropped directly using the mouse, it can be submitted to additional treatments (e.g. resize) offered by the image tab, as expected.
2) If the image is cropped after having activated the crop tool (by clicking on the crop icon) so that one has access to the crop toolbar, no issue for the crop itself (with the 'free' or preselected formats) but then no means to apply another treatment (all entries in the image tabs are then in grey, except the properties entry)
3) if I first click on the crop icon to have access to the crop toobar, then crop again to the crop icon to hide the crop toolbar and then crop with the mouse as in 1), the crop is done, but as in 2), all entries of the image tab are unavailable except 'properties', i.e. no subsequent treatment can be done
Thanks
simon
ps1. I saw in some other posts that disabling 'two-pass rendering at loading' could help, but in the present case, that did not change anything
ps2. No issue if things are made in the reverse order, i.e. some treatment first and the crop afterwards
Re: 1.5.0b1-2 crop+image treatments
right, will be fixed in b3
Is it fixed in beta3?
simon
Post by simon »
Fixed in beta3. Thanks.
In turn, the slider A/B of the compare tool stops working in beta3 (win 10 64 bits)
simon wrote: Fri Jun 23, 2023 8:29 am In turn, the slider A/B of the compare tool stops working in beta3 (win 10 64 bits)
could you create a new post and how to reproduce?
simon
Post by simon »
Oups, sorry, false alert: I attempted to use the slider A/B with two images with different sizes. With two images with the same size, it works as expected
