Cannot open GPS location
AndreasW
Post by AndreasW »
XnViewMP 1.50 beta 3 cannot open the GPS location of the attached image.
Other viewers, e.g. Apples Preview.app, are able to properly show the GPS location of the same image.
Vierwaldstättersee.avif.zip
(127.67 KiB) Downloaded 24 times
Re: Cannot open GPS location
it's works here. What do you have?
AndreasW
Post by AndreasW »
I have an iMac with Intel processor and macOS Ventura 13.4.1.
AndreasW
Post by AndreasW »
Screenshot:
ok i'll fix it in b4
please check b4
AndreasW
Post by AndreasW »
xnview wrote: Thu Jun 29, 2023 7:59 amplease check b4
It's fine now with the AVIF image in the first posting of this thread. Thank you very much!
BUT: It still doesn't work with the PNG image attached here to this posting:
in this png file there is no GPS datas
AndreasW
Post by AndreasW »
xnview wrote: Thu Jun 29, 2023 12:30 pm in this png file there is no GPS datas
Not true. There is GPS information, and other viewers are able to show it. It's even shown in XnViewMP's own ExifTool properties, see attached screenshot.
the GPS datas are in XMP, currently only GPS in EXIF are supported
AndreasW
Post by AndreasW »
That is very unfortunate. Such files are not a particularly special case.
Steps to get such a file:
1. Open any image (that has GPS in EXIF) in Adobe Photoshop Elements on Mac.
2. Save the file in PNG format.
Adobe Photoshop Elements is one of the most widely used image editing programs. And it does generate such files.
