Poor quality when opening HEIC file
AndreasW
Post by AndreasW »
Using XnView MP 1.5.0 on iMac with Intel processor.
When you open this HEIC file in XnView MP and zoom in 1:1 (100 %) on the man with the red jacket on the left side, the red jacket is poorly displayed. Details are lost and the color is too pale. This is particularly noticeable on the red hood of the jacket.
When opening the same image in Apple's Preview or GraphicConverter 12, this issue does not occur.
Please see the screenshot below for a direct comparison:
Re: Poor quality when opening HEIC file
not easy to see, which high zoom quality do you use?
AndreasW
Post by AndreasW »
xnview wrote: Wed Jul 19, 2023 7:41 am not easy to see, which high zoom quality do you use?
Zoom quality settings shouldn't matter when viewing 1:1 (100 %), right? Anyway, I tried all zoom quality settings, and the same issue was visible with all of them. I have an iMac 2020 with 27" display supporting P3 color space.
By the way, when storing the image in PNG format, the PNG file will have poor quality also when opened afterwards with other image viewers/editors. So the damage will permanent.
And yes, the quality is not absolutely terrible. But it's worse than in other programs. Even as a hobbyist, I'd like to have the best possible quality. So, this issue makes XnView MP unusable for me when it comes to opening HEIC files.
you're right, i have it on 1.5.0 but no more on the 1.5.1 which fix this issue
This problem is supposed to be fixed in XnView MP 1.5.1. Please check and confirm the bug fix here.
AndreasW
Post by AndreasW »
The problem is fixed in v1.5.1. Thank you very much!
