Save as AVIF doesn‘t work
AndreasW
Post by AndreasW »
Using XnView MP 1.5.2 on iMac with Intel processor.
Whenever I try to save an image in AVIF format, I get the error shown in the last screenshot below. XnView MP will create a file with the extension .avif having 0 bytes. The format of the original image doesn't matter. The file name doesn't matter either.
Re: Save as AVIF doesn‘t work
it's :bugconfirmed: AVIF is not supported on MacOS
AndreasW
Post by AndreasW »
It would be great XnView MP would support it. AVIF seems to be a useful format, it has better compression ratio than WEBP. GraphicConverter 12 on Mac does support it. So there's no general reason why it can't be done on Mac.
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
AndreasW
Post by AndreasW »
Not fixed. I still get the error "An error occurred during saving."
AndreasW wrote: Thu Oct 12, 2023 1:30 pm Not fixed. I still get the error "An error occurred during saving."
you need to install libheif with brew
AndreasW
Post by AndreasW »
xnview wrote: Thu Oct 12, 2023 1:34 pm you need to install libheif with brew
That's quite uncomfortable for the user. Other apps such as GraphicConverter are able to save files in AVIF format without such inconveniences.
yes i understand, i need to package the libheif library
AndreasW
Post by AndreasW »
Thank you very much for your efforts!
This problem is supposed to be fixed in XnView MP 1.6.1. Please check and confirm the bug fix here.
AndreasW
Post by AndreasW »
AndreasW wrote: Sun Oct 15, 2023 4:44 pm Not fixed. I still get the error "An error occurred during saving."
Currently there is only libraries for arm64 in the package
AndreasW
Post by AndreasW »
I have a Mac with Intel processor.
AndreasW
Post by AndreasW »
Today I got a new Mac with Apple chip, and I can confirm that saving as AVIF does work. Thank you very much!
