1.5.3: Can't browse folders on external USB S3+ SSD
Thargaris
Post by Thargaris »
I can't browse folders on my external USB S3+ SSD. The drive is correctly shown on the left of the UI and I can see folders and subfolders' structure but when I click on them nothing happens (XnView MP doesn't switch to them).
By using the contextual menu if I right click on a S3+ SSD folder to view it in XnView MP it opens a empty UI as in the attached screenshot.(D:\Downloads\Photos is the last XnView MP opened folder on HDD drive as I can't switch to S3+ SSD.)
XnView MP works fine on another external USB SSD disk (Intenso SSD) but not on USB S3+ SSD.
Further XnView Classic works fine on both external USB SSD disks.
My OS is Windows 11 22H2 Build 22621.2134
Thank you for your help
masterjp
Re: 1.5.3: Can't browse folders on external USB S3+ SSD
Post by masterjp »
Can you try it with admin rights again.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Thargaris
Post by Thargaris »
masterjp wrote: Sat Aug 19, 2023 2:45 pm Can you try it with admin rights again.
XnView MP was already ruuning as administrator. I had enabled it in Compatibility tab of xnviewmp.exe.
could you change xnview.ini
debug=2
, and send me logs when you try to access the folder on your SSD
Thargaris
Post by Thargaris »
Thank you Pierre,
I've sent you a private message.
Thargaris
Post by Thargaris »
xnview wrote: Wed Aug 23, 2023 3:03 pm :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
Big thanks to you Pierre. Keep up the good work
This problem is supposed to be fixed in XnView MP 1.5.4. Please check and confirm the bug fix here.
Thargaris
Post by Thargaris »
Hi Pierre,
I've just tried version 1.5.4 and it works well.
Regards
