Xmp files in Image View Mode after installing XnView Mp 1.5.3
OTRAG
Post by OTRAG »
Dear team,
after installing the new version XnView MP 1.5.3 the following error appears when working in Image View Mode:
After each image the corresponding *.xmp file is displayed.
In the corresponding tab the name of the image is displayed.
Scrolling to the next image is only possible via the arrow key in the top menu.
*.pp3 files are not displayed.
I use Windows 11 22H2 (Built 22621.2134)
Screenshot 2023-08-22 111259.png (48.61 KiB) Viewed 19490 times
Regards, Otrag
Re: Xmp files in Image View Mode after installing XnView Mp 1.5.3
OTRAG
Post by OTRAG »
Hello Pierre,
Thank you for your answer.
My case can be dropped with it.
Regards, Otrag
This problem is supposed to be fixed in XnView MP 1.5.4. Please check and confirm the bug fix here.
OTRAG
Post by OTRAG »
I just have install the new XnView MP version.
But, I can't confirm the bug fix. The bug is still there.
Sorry
Win 11 22H2 (Build 22621.2215)
XnView MP 1.5.4
Regards, Otrag
what do you have in Settings>View>Filter? Do you open the image from windows explorer or XnView browser?
OTRAG
Post by OTRAG »
Hello Pierre,
I am currently on the road and can therefore not answer the settings for View Filter. I will do so as soon as I am back in front of my computer.
I always open/view the images in XnView MP.
Regards, Otrag
OTRAG
Post by OTRAG »
Helle Pierre,
My settings concerning >View > Filter
Screenshot 2023-09-15 142333.png (23.28 KiB) Viewed 2387 times
I have removed the checkmark for "Text". With this, the viewer works as it should.
Thanks for the hint, the case can be closed with this.
Thanks for the support
Regards, Otrag
OTRAG
Post by OTRAG »
Hi Pierre,
This problem has been solved and the case can be closed.
Thanks a lot!
Regards, Otrag
