Search - controls focus - improve search sequence
XnViewMP 1.5.3 64bit
Search
split from Quick search/filter
search sequence is not fluent enough:
1. CTRL+F to open Search tool
current path will be inserted
2. type query
3. press Enter/Return (see Suggestion A)
3. click Search button
4. press Enter/Return (see Suggestion B)
4. click Browse... button
search results (if any) will be opened in Filelist as <Search results>
Suggestion A
'Add' button has focus, so its not possible to run search by pressing Enter/Return once query is typed, that is not convinient.
its better to set focus to 'Search' button
Suggestion B
no button has focus, that is not convinient.
its better set focus to 'Browse...' button
Re: Search - controls focus - improve search sequence
This problem is supposed to be fixed in XnView MP 1.5.4. Please check and confirm the bug fix here.
A - done
