Show custom EXIF tag on info panel?
FKCapitalism2
Post by FKCapitalism2 »
I want to display [EXIF:Camera] Digital Zoom Ratio when i tried {EXIF:Digital Zoom Ratio} its not working
Re: Show custom EXIF tag on info panel?
Makernotes field?
FKCapitalism2
Is there way to specify custom exif tags to display in case XnView MP does not have preset for it?
xnview wrote: Wed Aug 30, 2023 1:38 pmMakernotes field?
What do you mean?
Its described in EXIF reference manual
Please try {EXIF: xa404}
FKCapitalism2
xnview wrote: Fri Sep 01, 2023 7:51 am Please try {EXIF: xa404}
Does not work, i uploaded source file here: https://www.upload.ee/files/15640889/20 ... 6.zip.html
Please try {EXIF:xA404}
FKCapitalism2
xnview wrote: Fri Sep 01, 2023 2:11 pm Please try {EXIF:xA404}
That works, thank you.
in 99% of files it shows zoom properly however here is one file where digital zoom ratio = 6.12 inside EXIF, but in XnViewMP it shows as digital zoom ratio = 153/25 which requires use of calculator to figure out actual number.
Source file: https://www.upload.ee/files/15641242/20 ... 5.zip.html
FKCapitalism2 wrote: Fri Sep 01, 2023 3:35 pm in 99% of files it shows zoom properly however here is one file where digital zoom ratio = 6.12 inside EXIF, but in XnViewMP it shows as digital zoom ratio = 153/25 which requires use of calculator to figure out actual number.
This problem is supposed to be fixed in XnView MP 1.5.4. Please check and confirm the bug fix here.
FKCapitalism2
xnview wrote: Tue Sep 05, 2023 1:31 pm This problem is supposed to be fixed in XnView MP 1.5.4. Please check and confirm the bug fix here.
Fixed thanks.
FKCapitalism2
Can i also show other tags not specified in EXIF manual.
In particular this three.
