b3: Reset x/y. Option not saved.
Locked
marsh
Post by marsh »
Problem: This option is not remembered in ini.
Its a new view option in beta3. It seems to work with 'fit image to window width'. Its purpose seems to be to make the next picture start out at top, instead of last position used in previous picture. Should this option be ON by default?
marsh
Does not work in preview fullscreen
Post by marsh »
Original problem fixed.
This option only works in viewer. It doesn't work in preview fullscreen.
Dreamer
Re: Does not work in preview fullscreen
Post by Dreamer »
marsh wrote:Original problem fixed.
Moved back to New/Open.
marsh
Post by marsh »
Problems above are fixed.
Another problem remains:
This option should be greyed out at startup when another 'auto size' option is displayed other than fit horizontally/vertically.
marsh
Post by marsh »
Fixed. RC3
Locked
