Fatal crash: 1.5.4 abends when opening subfolders
lphilpot
Post by lphilpot »
XNView MP 1.5.4.0 64 bit Libformat 7.154
Windows 11 Home
Just downloaded and installed, this bug is reproduceable.
When I try to open certain folders (usually the last child in a branch) either by double-clicking the thumbnail or selecting it from the folder tree, XNView crashes without any error message. It's happened 10+ times so far on different folders, but has worked successfully on a few other folders. However, there's nothing different about any of these folders and they all open without incident in other programs -- including other image viewers. The security is no different on the folders that fail. I've not added new folders nor made any changes, etc. These folders have been here for months with no changes other than images added / deleted in them. Other than images "coming and going", it's a static environment.
I confirmed the signature of the installer is good. I renamed my user folder (in AppData\Roaming) and tried again with a clean config, but it still crashes in the same manner. There's no error message and I don't know where to get logs (I looked under AppData\Roaming and Local).
Where can I download the last version (1.5.3 64 bit) so I can work until this is fixed?
Thanks.
Len Philpot
Re: Fatal crash: 1.5.4 abends when opening subfolders
lphilpot wrote: Wed Sep 06, 2023 5:05 pm Where can I download the last version (1.5.3 64 bit) so I can work until this is fixed?
Old versions :D
Perhaps the link could be made easier to find, but I'm not sure how?
lphilpot
Post by lphilpot »
I saw that, but this is why I didn't even go there:
2023-09-06 12_24_15-Clipboard.png (16.53 KiB) Viewed 2699 times
The label needs to be updated.
Len Philpot
lphilpot wrote: Wed Sep 06, 2023 5:05 pm When I try to open certain folders (usually the last child in a branch) either by double-clicking the thumbnail or selecting it from the folder tree, XNView crashes without any error message. It's happened 10+ times so far on different folders, but has worked successfully on a few other folders. However, there's nothing different about any of these folders and they all open without incident in other programs -- including other image viewers. The security is no different on the folders that fail. I've not added new folders nor made any changes, etc. These folders have been here for months with no changes other than images added / deleted in them. Other than images "coming and going", it's a static environment.
You can reproduce each time? which formats do you have in this folder?
philalethia
Banned
Post by philalethia »
lphilpot wrote: Wed Sep 06, 2023 5:25 pm I saw that, but this is why I didn't even go there:
Ah, no. That link, points to the exact same file, as the link to the current version.
lphilpot
Post by lphilpot »
In the bottom folder it's TIFFs, JPGs and an Affinity Photo file (.afphoto) or two. In the immediate parent folder it's (Canon raw) CR3s and maybe another raw file of some other format (Sony ARW, etc.). Plus there are a few sidecars, xmp and other text formats. Nothing unusual at all.
None of those are an issue with any other programs, including all previous versions of XNView. I reinstalled 1.5.3 and all is ok again.
Thanks.
Len Philpot
lphilpot
Post by lphilpot »
xnview wrote: Thu Sep 07, 2023 1:37 pm :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
OK, it's related to TIFFs. That would explain why it happens on most, but not all, folders. Due to my raw processing photo workflow, I tend to have TIFFs "left over" in a folder more often than not. There are only a relative few image folders that don't contains at least one TIFF.
Thanks.
Len Philpot
This problem is supposed to be fixed in XnView MP 1.5.5. Please check and confirm the bug fix here.
lphilpot
Post by lphilpot »
xnview wrote: Fri Sep 08, 2023 2:47 pm This problem is supposed to be fixed in XnView MP 1.5.5. Please check and confirm the bug fix here.
No crashes so far! Thanks.
Len Philpot
