I will try and see if that works.
Hangs on startup with "rainbow circle" about 1/2 the time on MacOS
pointy
pointy
Re: Hangs on startup with "rainbow circle" about 1/2 the time on MacOS
Also, to be clear, *it does not always hang*. It does quite often, but sometimes without me touching the .ini file (because I just forget to do that sometimes), it works. And sometimes it does not work. I cannot predict it.
ok, so when you have the problem please check PathBrowser & History?pointy wrote: Thu Sep 14, 2023 5:52 pm Also, to be clear, *it does not always hang*. It does quite often, but sometimes without me touching the .ini file (because I just forget to do that sometimes), it works. And sometimes it does not work. I cannot predict it.
