1.6.1 Batch Convert Presets vanish randomly
XnSoldier
Post by XnSoldier »
Version 1.5.2 worked fine. Now in 1.6.1 the used preset list slowly empties. After exiting Batch Convert one or several presets get deleted from the list.
I started with 7 presets, then it was 4 then 2, then 1 then nothing left.
XnView Presets.png (6.64 KiB) Viewed 1682 times
Photographer. Sorting 100.000-250.000 pics per year
20 years with ACDSee Photo Professional. Love and Hate. I would love to see XnView MP upgraded for better editing or a commercial "XnPhoto Pro"! Keep up the great work!
Re: 1.6.1 Batch Convert Presets vanish randomly
same as this issue
XnSoldier
Post by XnSoldier »
yeah. Probably the same. For me they vanish when closing Batch Processing not only when I close XnView.
I had used the search function for existing bugs but I was looking for "presets" while other post is using "preset" only ;-)
Looking forward to a fix.
This problem is supposed to be fixed in XnView MP 1.6.2. Please check and confirm the bug fix here.
XnSoldier
Post by XnSoldier »
Great. Thanks for fixing. I can see the download page. But XnViewMP Version 1.6.1 on windows states there is no update.
XnSoldier wrote: Wed Nov 22, 2023 1:43 pm XnViewMP Version 1.6.1 on windows states there is no update.
Version 1.6.2 is available on this link and also on the xnview.com home page... ??
XnSoldier
Post by XnSoldier »
yes, it is available on the homepage but within the software no update was found.
