heic format and Keywords
Estuff
Post by Estuff »
It appears that XnView does not read keywords in the metadata of heic format image files.
Re: heic format and Keywords
you need to use XnView MP
Estuff
Post by Estuff »
I downloaded XnViewMP and it still does not work. Every other tools sees the keywords in the .heic file but XnViewMP does not. It does work with .jpg files that have keywords but not the .heic files.
Estuff wrote: Wed Nov 15, 2023 6:42 pm I downloaded XnViewMP and it still does not work. Every other tools sees the keywords in the .heic file but XnViewMP does not. It does work with .jpg files that have keywords but not the .heic files.
please send me a sample file?
Estuff
Post by Estuff »
Pierre
I am happy to send you the photo but when I try to attach it says the file is too big. it is only 2.2MB. Can I email the you the file?
yes contact at xnview dot com
This problem is supposed to be fixed in XnView MP 1.6.3. Please check and confirm the bug fix here.
Estuff
Post by Estuff »
I have verified that the problem was fixed!!!! Thank you so much!
