Directory names
MartinP
Directory names
Post by MartinP »
Hi all,
since the update to the 1.6.1 64bit the thumbnails of the directories displayed in the thumbnail view dont show their names anymore. The names are there, if you click rename you can see the name. So it looks like the names of directories are displayed in the background color.
Thanks and cheers
Martin
MartinP
Re: Directory names
Post by MartinP »
Hi all,
found it: it is a change in behavior
in my ini, I had configured 2 information lines per file:
1. line: Custom 3: {Filename With Ext} | {Size KB} kb
2. line: Custom 2: {Width}x{Height} | {Size KB} kb | {EXIF:Focal Length}mm | f/{EXIF:F-Number} {EXIF:Exposure Time}s {EXIF:ISO Value} iso
That works brilliant for all files, but does not show the folder names anymore, as before.
Folder names are only shown - as it seems - with "Filename {with extension}" in one of the info lines.
I can live with that, but never the less, it is a change in behavior. I cannot tell, if it did come with 1.6.0, as I skipped this version.
Thanks & Cheers
Martin
Re: Directory names
Re: Directory names
This problem is supposed to be fixed in XnView MP 1.6.2. Please check and confirm the bug fix here.
MartinP
Re: Directory names
Post by MartinP »
Hi Pierre,
sorry for my late response, it was a quite busy time - I've tested it today with version 1.6.3 and it does work.
Cheers
Martin
