1.6.2 Import and Sort Problem
slademann
Post by slademann »
Hi Pierre
This is a problem that I've had (and you fixed) before which has returned.
Using "Import and Sort" on a Nikon-produced SD card, I get the error as attached.
I get similar (but not the same) errors whether I move or copy the files.
The files being imported are .nef Nikon raw files with accompanying .jpg files.
I've also included the Companion File settings, as these were key to fixing the problem last time.
Still think this app is better than anything else I've come across, so keep up the great work!
Steve
Re: 1.6.2 Import and Sort Problem
which settings do you have for 'import&sort'? Could you send sample files to reproduce?
slademann
Post by slademann »
Hi Pierre
Thanks for getting back. The Import & Sort options are as follows. Forgive the temporary directories, they are for testing purposes.
The files I'm using for testing are here https://1drv.ms/f/s!AsOHF3QeIkc83W2P8MH ... j?e=bGWTa7
BTW, I've downgraded to 1.5.5 and it all works perfectly, this may help to pin down the problem.
Best Regards
Steve
This problem is supposed to be fixed in XnView MP 1.6.3. Please check and confirm the bug fix here.
slademann
Post by slademann »
Hi Pierre
Yes, I can confirm that 1.6.3 has fixed the problem, many thanks.
Best regards
Steve
