Date on folder labels
Zheitk
Post by Zheitk »
I just update to XnView MP 1.6.2 64-bit (windows). I don't remember which version I had T__T.
I might be misremembering things, but I was sure folders had the modified date below the folder name.
Now they only have the folder name and two empty rows.
Unfortunately I can't find an older version to test.
Under settings > thumbnail > labels I have on the third row "File created date". Can´t find an option to show the date of folders.
If there was never such an option, I would like to suggest the ability to have different labels on folder and image thumbnails, so folders will have: Name, Created Date, Modified Date.
Re: Date on folder labels
Zheitk wrote: Sun Dec 03, 2023 6:09 pm I just update to XnView MP 1.6.2 64-bit (windows). I don't remember which version I had T__T.
Old versions :D
Post by michel038 »
Right,
I tested v0.99.4 , file ceated date could be displayed for folders ...
Zheitk
Post by Zheitk »
cday wrote: Sun Dec 03, 2023 6:27 pm Old versions :D
Thanks!!
michel038 wrote: Sun Dec 03, 2023 7:55 pm Right,
1.6.2 & 1.5.5 don't show any dates on folders.
1.4.5 still display both created and modified!
This problem is supposed to be fixed in XnView MP 1.6.3. Please check and confirm the bug fix here.
Zheitk
Post by Zheitk »
Can confirm it's fixed :D
