1.6.3 IPTC XNview does not open templates
runber
Post by runber »
XnView: MP 1.6.3 - 64-bit
OS: Windows 11 - 64-bit
Effect: XNview does not open IPTC-templates. The fields remain empty. Version 1.6.1 still worked.
1. Browse a folder and select one or more image files (JPEG format).
2. Go to "Edit IPTC" (Button toolbar or right mouse Metadata)
3. Load template (open any template)
4. The fields are empty ...
5. Only manual entrys are working.
6. You can save new templates - but the result remains the same.
Re: 1.6.3 IPTC XNview does not open templates
This problem is supposed to be fixed in XnView MP 1.6.4. Please check and confirm the bug fix here.
runber
Post by runber »
Hallo. Mit Version 1.6.4 ist der Fehler behoben. VIELEN DANK :D
