1.6.3 (x64) Win10: "Tag" action glitch found
peterg91
Post by peterg91 »
XnView: MP 1.6.3 - 64-bit
OS: Windows 10 - 64-bit
XnView misses to display tagged items properly..
Effect: Annoying cosmetic-like bug
1. Switch to "details" item list to see no items tagged.
2. Hit CTRL A to pick all items, then hit CTRL T to tag them --> only video files are displayed with tag checkbox, images are not
3. When switch to "Thumbs" view, however images are showing tag checked, videos are not
4. Going back to "Details", again nothing tagged
5. Going back to "Thumbs", images keep tagging..
6. Having dbase/catalog off/on is irrelevant to see the change..
7. Question: When picking all including subfolders in given folder, why the app just does not tag files as it does not tag anything? Feature or bug too?
Actual behaviour (bug): XnView falsely display tag information
Expected behaviour: Correct tag information
Re: 1.6.3 (x64) Win10: "Tag" action glitch found
if you use default theme, the problem is gone, right?
peterg91
Post by peterg91 »
Hello Pierre,
right that. I natively during night time of installing I assume, just picked the dark scheme... no problem with default one.
Thanks
BR
Peter
This problem is supposed to be fixed in XnView MP 1.6.4. Please check and confirm the bug fix here.
peterg91
Post by peterg91 »
Hello, confirmed working. Bug closed.
