RC1: Slide show process stays in the backround
When I close exe slide show by doubleclicking it, the process stays in the backround.
Re: RC1: Slide show process stays in the backround
When you create a slide exe with only 2 pictures, do you have a problem?ckv wrote:When I close exe slide show by doubleclicking it, the process stays in the backround.
I have hard time to test this because most of my slide exes don't work at allxnview wrote:When you create a slide exe with only 2 pictures, do you have a problem?ckv wrote:When I close exe slide show by doubleclicking it, the process stays in the backround.
==> http://newsgroup.xnview.com/viewtopic.php?p=22666#22666
Fixed in RC2.
