UI is unresponsible if opened from a folder with a large number of images
Re: UI is unresponsible if opened from a folder with a large number of images
if you have delay between
SORT the list...[/quote] and [code]## OPEN FOLDER done  1174
, its only files list sorting....
Files are added one by one in database
Litr
Post by Litr »
Yeah the UI is already responsible when the database activity log starts to display. I hope some day you will fix this or at leas speed it up.
Perhaps it would be possible to load folder information after unlocking the UI, rather than before?
I mean, I don't need the entire folder list if I just want to see a couple of nearby images (if after opening the first file I will use the previous or next file) or even just one image (if I don't even want to see previous or next file).
Litr wrote: Thu Jan 15, 2026 8:20 am I mean, I don't need the entire folder list if I just want to see a couple of nearby images (if after opening the first file I will use the previous or next file) or even just one image (if I don't even want to see previous or next file).
Yes, the problem is if you need to use next/previous file, XnView needs to load full filelist...
