Viewer - save routine - reduce number of dialogs when saving image with comments and other metadata
XnViewMP 1.6.4 64bit
Viewer
when saving image with comment and other metadata to a format that does not support them, 2 dialogs are displayed one by one
  • show only one dialog for such cases
Re: Viewer - save routine - reduce number of dialogs when saving image with comments and other metadata
which dialog will be better?
cicciobello
Post by cicciobello »
I think the second one is better (shorter writing).
i would:
- use the 2nd dialog as more general (since all metadata is removed, no need to mention comment separately)
- replace "any existing" with "all" or "all embedded" if it fits dialog without breaking sentence (in English) to the second line
follow up Suggestion
guess separate post required
Keeping in mind there is another dialog - "Saving in this format will delete some metadata!"
(eg when saving image with XMP metadata into PNG), you my want to list the exact metadata which will be saved/removed from file.
Sorry I did not understand, :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
fixed in 170
(1st dialog is in use)
