I notice this accidentally while testing handle leak => http://newsgroup.xnview.com/viewtopic.php?p=22581#22581
When you view files as list in browser, the file name backround color for the different file types disappears while browsing. If you change the view as to list mode, the colors are there and when you browse to a different folder the colors disappear.
RC1: Colors in view as list mode bug?
Re: RC1: Colors in view as list mode bug?
Color is used on file format, not on file extensionckv wrote:I notice this accidentally while testing handle leak => http://newsgroup.xnview.com/viewtopic.php?p=22581#22581
Yeah that is what I ment by the file type. So is there a bug or what? View files as list mode don't have those colors.xnview wrote:Color is used on file format, not on file extensionckv wrote:I notice this accidentally while testing handle leak => http://newsgroup.xnview.com/viewtopic.php?p=22581#22581
Occurs also with clean ini.
Get my ini: xnview.ini
In list there is no file read, so colors can not be usedckv wrote:Yeah that is what I ment by the file type. So is there a bug or what? View files as list mode don't have those colors.xnview wrote:Color is used on file format, not on file extensionckv wrote:I notice this accidentally while testing handle leak => http://newsgroup.xnview.com/viewtopic.php?p=22581#22581
OK. Thanks. So I guess that this can be closed.xnview wrote:In list there is no file read, so colors can not be usedckv wrote:Yeah that is what I ment by the file type. So is there a bug or what? View files as list mode don't have those colors.xnview wrote: Color is used on file format, not on file extension
