thumbnails for .cbr and .cbz files
Re: thumbnails for .cbr and .cbz files
171
all issues remain
issue C
after opening cbz (from Browser) the following record appears in Catalog:
all issues remain
issue C
yep, default unzipped version
aticus
Hi! with the version 1.7.1 I have the same problem.
No thumbnails even after 'rebuild thumbnails'?? On clean ini, it works
on clean ini it looks like this:
after going to Settings > File List > Custom Filter and clicking OK, they become blank
'rebuild thumbnails' does not help
So it's ok
The 1st file is 'Sin título-23.jpg' not 'Sin título-01.jpg'
Why, is it defined by format itself?
Because among all sorting options I cannot find the one that will put 'Sin título-23.jpg' in the 1st place.
Files inside cbr/cbz respect Browser's sorting settings (sorted A-Z by name by default),
but for the purpose of thumbnail generation I think only A-Z soring by name should be used.
As its always assumed that first and last files are covers.
When you choose 'no sort' you can view the order of files in archive.
where is this option?xnview wrote: Thu Apr 11, 2024 6:14 am When you choose 'no sort' you can view the order of files in archive.
ok, 7-Zip has Unsorted option that puts 'Sin título-23.jpg' in the first place.. the order, files were added to the archive
as for me, it does not make much sense to respect this order as it rarely intentional
