thumbnails for .cbr and .cbz files
aticus
Re: thumbnails for .cbr and .cbz files
Post by aticus »
xnview wrote: Tue Apr 09, 2024 2:35 pm
aticus wrote: Tue Apr 09, 2024 10:41 am Hi! with the version 1.7.1 I have the same problem.
No thumbnails even after 'rebuild thumbnails'?? On clean ini, it works
No thumbnails even after 'rebuild thumbnails, with .cbr and .cbz files.
please send me your xnview.ini
aticus
Post by aticus »
xnview wrote: Fri Apr 12, 2024 11:54 am please send me your xnview.ini
Sorry boss. In a portable xnViewMP, with a new xnview.ini, I can now see the covers.
What would I need to change in the other xnview.ini so that I can also see them in the installed xnView?
Thank you very much!
aticus
Post by aticus »
aticus wrote: Fri Apr 12, 2024 4:29 pm
I'll complete my answer. By changing some options related to views in the portable xnviewmp (hiding panels, hiding thumbnail labels, and removing ratings from the toolbar), the covers have stopped being displayed.
which settings do you have changed?
PacoFR
Post by PacoFR »
Hi Pierre,
Même problème ici : avec XnviewMP 1.7.1 additionné d'un ancien fichier .ini (pas si vieux, version 1.6.5 si j'ai bonne mémoire), les vignettes cbr et cbz ne se construisent pas.
Les vignettes cbr et cbz s'afficent correctement en supprimant le fichier .ini.
Voulez-vous mon ancien fichier .ini pour voir ce qui bloque ?
PacoFR wrote: Sun May 05, 2024 5:10 pm Voulez-vous mon ancien fichier .ini pour voir ce qui bloque ?
oui
Enlevez thumbnailFilter de votre fichier .ini
PacoFR
Post by PacoFR »
Merci Pierre ; l'astuce fonctionne !
aticus
Post by aticus »
xnview wrote: Mon May 13, 2024 6:42 am Enlevez thumbnailFilter de votre fichier .ini
hI! Here that solution works too. May you explain why? Thanks!!!
aticus
Post by aticus »
Now I can see the CBR thumbnails, but suddenly the video thumbnails no longer show frames of the video (only the player icon)
aticus
Post by aticus »
Ok, I think I understand what's happening.
If I remove the "thumbnailFilter" line from the .ini file, I lose the display of video thumbnails.
If I go into the options and check "Show as thumbnail" again in "File list/Custom filter/Video", I see the video thumbnails again, but I lose the .cbr and .cbz thumbnails.
Another problem I've found, I don't know if it's related, is that when I opened a .zip file that contained a folder, the folder icon was displayed with an image of one of the images inside. That makes sense. If I click on that icon, I can see the images inside (all without decompressing the file). The problem is that now I open another file (a .cbr in this case) that also has the images in a folder, the thumbnail of this folder is the one from the folder of the other .zip file. I have rebuilt thumbnails, deleted the cache, and nothing.
aticus wrote: Wed May 15, 2024 4:47 pm Ok, I think I understand what's happening.
I've tried but no problem. Which value do you have for thumbnailFilter?
aticus
Post by aticus »
xnview wrote: Tue May 21, 2024 6:51 am
thumbnailFilter=65531
aticus wrote: Tue May 21, 2024 3:21 pm
ok, please wait next release...
