1.7.0 regression: use color profile causes gif not showing
fireattack
Post by fireattack »
This is a regression in 1.6.x, 1.7.0. Cannot reproduce in 1.4.5.
1. Go settings -> Color profile -> check "Use ICC profile for monitor".
2. Prepare a folder with two images, one jpeg and one animated GIF (larger one is preferred.) You can download the two images I used for testing here: https://1drv.ms/u/s!Akq11jtCTJYwifEuE8A ... w?e=9ptJdY
3. Open the JPEG in viewer first.
4. Go next to the GIF image by scrolling, or arrow key.
Expected: animated gif playing
Observed: the only a transparent check pattern is showing:
If you open the GIF directly (from browser or explorer), it mostly would show correctly (but it would still be broken from time to time). But if you open another file first and then scroll to the GIF, I can 100% reproduce the bug.
Re: 1.7.0 regression: use color profile causes gif not showing
do you reproduce with latest version?
fireattack
xnview wrote: Thu Apr 11, 2024 2:10 pm do you reproduce with latest version?
Yes can reproduce with 1.7.1.
ckit
Post by ckit »
fireattack wrote: Sat Apr 13, 2024 1:35 pm
Confirmed!
This problem is supposed to be fixed in XnView MP 1.7.2. Please check and confirm the bug fix here.
ckit
Post by ckit »
Bug Fix Confirmed in XnViewMP 1.7.2, Thank you!
