1.8.0: can't open EXR files with paths containing non-ASCII charcters
Lex-DRL
Post by Lex-DRL »
Description in subj ☝🏻
Oddly enough, other file types (png, jpg) can be opened from the same folder with no problem.
XnView: MP 1.8.0 64-bit Libformat 7.192
OS: Windows 10 - 64-bit
1. Create a folder containing non-ASCII characters. E.g., default "new folder" name in any Windows localization other than English. E.g., Russian:
Новая папка
2. Put an EXR file into this folder.
3. Try opening it with XnView MP.
Effect: an error pops up saying the file can't be opened.
Expected behaviour: It should be opened 😄
Re: 1.8.0: can't open EXR files with paths containing non-ASCII charcters
Lex-DRL
Post by Lex-DRL »
Fixed, thanks (at least, with the same non-ASCII characters: i.e., cyrillic).
