Please, don't post bugs or requests in this topic!
You can download XnView MP 1.8.2 here:
Windows x64 ZIP version SHA256: 4F8D0BE375227E43DF0DA31FAED2A03D7057E5F3D8C5372E593F308CDBF26C24
Windows x64 SETUP version SHA256: 957892DE2A7E5ED941964A6693BA69EDC6961BA00F10BD86ECCAB1CF6B4C4839
Mac x64 DMG version SHA256: 382E6E3CDC4C251DD65836EF067AC5A9109FC044654FD99445055FB592DA1685
Linux x64 TGZ version SHA256: 534E5A0BDF483ED88CFA5A4EA2429DAAAEBB9111C4D8AB133455558486DABAD4
Linux x64 DEB version SHA256: 52E7EE4250381FEC29BDF0225F3D5E4FC4C7141933C3F13A9A681A4EA2DB67A3
ARM version: https://download.xnview.com/XnViewMP-linux-arm.tgz https://download.xnview.com/XnViewMP-li ... _armhf.deb
Linux x64 AppImages version: https://download.xnview.com/XnView_MP.g ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 1.8.2:
3400: [Bug] Viewer - image changed after delete or export - viewtopic.php?f=62&t=47947
3399: [Bug] Viewer - greyed nav button after save as - viewtopic.php?f=62&t=47948
3398: [Bug] Windows - dav1d not used for avif - viewtopic.php?f=62&t=47936
3397: [Bug] JPEG-li - subsampling - viewtopic.php?f=62&t=47949
3396: [Bug] Settings - Keyboard - Automatic - viewtopic.php?f=104&t=47373
XnView MP 1.8.2
XnView MP 1.8.2
Re: XnView MP 1.8.2
When viewing full screen single left click of the mouse used to zoom to 100 percent while it was held down.
It is no longer doing that is it set in an option somewhere?
Re: XnView MP 1.8.2
In the batch window will have presets and a list of files we have previously used
this is normally sorted in the order of the most recently used script
this is usually saved between closing and opening the main window
it is no longer saved
Re: XnView MP 1.8.2
@Obelisk:
It would be helpful if you could post under the XnView MP - Bug reports heading...
