Drag and drop to folders pane causes freeze Linux Fedora 41
Re: Drag and drop to folders pane causes freeze Linux Fedora 41
currently the only workaround is to use X11
Kenny Dave
Okay so it doesn't seem possible to run x11 in Fedora 42. But for the flatpak version, in flatseak, turning off permissions for "Wayland windowing system" and "fallback to x11" seems to be working without freezes on a 5 min check.
Thanks Pierre.
Edit: seems stable on a longer test also. Having issues crashing when an mp4 is selected though, I think that is a different issue.
Thanks Pierre.
dandv
Ubuntu 25.04, XnViewMP 1.9.3, KDE 6 Wayland. I can reliably reproduce the freeze when:
- dragging a subfolder onto another place in the tree
- dragging a group of files into a folder
Denyer
Same issue with KDE Plasma 6 on Wayland under Debian 13. Running the specific executable under XWayland gives a partial workaround, although does mean that some window manager functions won't work.
XDG_SESSION_TYPE=X11 xnview
If running Plasma you can Edit Application on your app menu and put the XDG bit into the environment variables field, although the same may be needed for any file manager actions, etc.
Haven't come across similar issues so far with any other Qt apps that implement drag-and-drop.
edit: Also, it seems to be a one-way issue dragging files between XnViewMP and a file manager such as Nemo. You can successfully drag a file from XnViewMP to Nemo and it'll work. If you drag a file from Nemo to XnViewMP, the file is copied but then XnViewMP hangs/freezes. Is the bug that XnViewMP is waiting for confirmation of the file operation (or something else) to complete so that it can redraw but doesn't get it?
dandv
I can still reproduce the freeze on Ubuntu 24.04 with KDE 6 Wayland, when dragging a file onto a directory within XNView MP.Denyer wrote: Sun Jan 04, 2026 7:47 pmit seems to be a one-way issue dragging files between XnViewMP and a file manager such as Nemo.
The AppImage also crashes when attempting to play MP4 files, but that's another issue.
Denyer
Sorry, didn't mean to imply otherwise. I get the following results:
XnViewMP dragging to another location within same instance of XnViewMP - freezes
Nemo file manager to an XnViewMP window - XnViewMP freezes
XnViewMP dragging to another XnView window -- the original is okay but the destination freezes
XnViewMP to a Nemo file manager window -- works
In all cases the file operation seems to complete successfully independently of the freeze behaviour.
So I think the issue is that XnViewMP may be waiting for some sort of signal that it doesn't get. Logically that's either Wayland behaving differently to X11 in terms of signalling, or Wayland itself somehow causing XnViewMP to freeze.
Which is the sort of behaviour that's been seen in other apps sometimes under Wayland, although Chromium is a complex piece of software so it could have been something else entirely there, e.g. https://bugs.kde.org/show_bug.cgi?id=482142
Cutting/copying/pasting via shortcut keys in XnViewMP seems to be a workaround, until the user forgets that drag-and-drop is broken.
If it's Wayland itself that's considered to be the problem then it'd be useful if drag-and-drop file operations could be disabled through an option, since Wayland sessions by default are fast becoming the norm. This thread -- viewtopic.php?t=45990&start=15 -- suggests that's possible although I don't think it's exposed as an option through the GUI and I've just tried putting noDrag=true into the relevant xnview.ini under [Browser] and restarted XnViewMP and it didn't appear to work.
Denyer
Interestingly, it appears that the frozen XnView window can be brought back to life.
Steps to reproduce:
1. In XnViewMP, drag file.jpg from Folder1 to Folder2. XnViewMP freezes although the file has been successfully moved from Folder1 to Folder2.
2. In a file manager (I'm using Nemo) create a new file in Folder1 such as a new text document, or move a file into Folder1. XnViewMP unfreezes.
Sometimes creating/moving a file in another folder in the same hierarchy will have the same effect. Sometimes XnViewMP doesn't freeze again for a while, apparently until it's being used with different folders that aren't also being used in the file manager.
This would seem to support the theory that XnView is waiting to be told that a folder's contents have changed, or some other signal to refresh. When it gets whatever signal it's waiting for it refreshes itself.
Steps to reproduce:
Kenny Dave
You can see the wait condition if you open XNViewMP in terminal. Resultant messaging is in a post above.Denyer wrote: Sun Jan 11, 2026 4:43 amThis would seem to support the theory that XnView is waiting to be told that a folder's contents have changed, or some other signal to refresh. When it gets whatever signal it's waiting for it refreshes itself.
xnview_igel
I came here to confirm the findings mentioned in this thread.
the flatpak version of XnView is crashing when moving an image file (drag and drop) from the browser view.
It crashing when moving within the same folder panel or when moving from the folder view panel into a folder in the folder tree pane.
the move operation does suceed, though the GUI freezes, the file is apparening as still available and selected. In a file manager that ran in parallel I confirmed that the file was already move to the new location. And indeed creating a text file in the folder the image file was moved from, immediately unfroze XnView, like mentioned a little above.
Unselecting "Wayland windowing" in flatseals allows moving files without freeze, but unfortunately for me the GUI is totally unusable due to tiny icons (I have a 4K laptop screen).
reproduced with the current XnView flatpak version from March 16, 2026
on Manjaro KDE Walyand 6.18 LTS fully updated to version from March 23, 2026
on Fedora 43 KDE Wayland 6.19-8 fully updated as of today
it did not differ if the move operation was done within a folder reachable by the flatpak container (home) or a folder that was added to flatpak via the --override option or via Flatseal (additional hdd partitition). user rights were given for the file system access.
hope this helps in order to resolve this issue.
I am about to fully move to Linux, and I have been using XNView for 20 years on Windows to organise my photo archive. Would like to keep using it on Linux as well...
xnview_igel
Addition: the same behaviour appears to happen also in non-flatpak apt package of XnView 1.10.5 (Mar 16 2026) that is delivered through the MX Linux / Debian repositories. Also here XnView is only coming back to life if a new file is created in the folder that is on display in the GUI (or the moved file is moved back).
MX Linux 25.1 KDE Wayland
I hope that the solution can be found soon to fix that bug.
moving files per drag and drop is a key feature for an image browsing tool, I personally depend heavily on it in my photo organisation workflow and can imagine a lot of other users do too. At the moment its a show stopper.
Could it be helpful to notify upstream developers in case the problem is caused by KDE / Qt interaction?
Thanks for the effort you put in XnView!
jkm
You might consider trying a different distro with a different variant of Wayland. Gnome Wayland, wlroots Wayland, etc.
You’re just seeing the tip of the iceberg with Wayland issues, and drag and drop is a big part of that, and not just with XnViewMP. Google it and you’ll get an idea.
Different things have different issues on different variants of Wayland. Good luck…
