1.8.3 - browser/viewer - shortcut to raw renders differently
XnViewMP 1.8.3 64bit
Windows11 (24H2), display resolution 3840x2160, win scaling 150%
Browser / Viewer
there is difference in raw image rendering when using shortcut
to reproduce
1. have raw file in folder (eg blackbird.nef, 19Mb [source]) + its shortcut
2. open folder in Browser
issue A
3. click on original
it renders as expected in Preview pane
4. click on shortcut
it renders lighter than original in Preview pane
issue B
5. double click on shortcut to open file in Viewer
it renders lighter than original in Viewer
Re: 1.8.3 - browser/viewer - shortcut to raw renders differently
i can't reproduce, which nef file do you use?
I have updated post with some details
This problem is supposed to be fixed in XnView MP 1.9.0. Please check and confirm the bug fix here.
fixed in 190
