DivX and XviD
ckit
Schattenreiter
Well, if you use VirtualDub, then I guess it is pretty useless.ckit wrote:I know everyone likes X264 but if it can't be used in VirtualDub what use is it?
But if you use a different front-end, like VisualHub for example, it is the best choice.
Always depends on the front-end, that is... but that's just my 2 cent.
HackIntosh
Mountain Lion 10.8.2 • G530 • GA-Z77M-D3H • Sapphire 5770 • Soundblaster Audigy Platinum • 16GB-1333-DDR3 • Atheros AR9280
foxyshadis
ckit
Yes and I appreciate itfoxyshadis wrote:I just linked to the installer so that you could use it in virtualdub!ckit wrote:I know everyone likes X264 but if it can't be used in VirtualDub what use is it?
