Folder ratings disappear
Ilikemyprivacy
Re: Folder ratings disappear
Post by Ilikemyprivacy »
I've just done it with the latest version of XnView. I went from 1.9.2 to 1.9.3.
if you go back on 1.9.2, rate folders and install 1.9.3?
Ilikemyprivacy
I didn't go back, I was already on 1.9.2 and then I updated to 1.9.3.
Ilikemyprivacy wrote: Mon Aug 25, 2025 3:49 pm I didn't go back, I was already on 1.9.2 and then I updated to 1.9.3.
Please try again? but updating to 1.9.3 dont remove rating on folder...
Ilikemyprivacy
I reinstalled 1.9.3 and the problem doesn't exist if I install the same version I had before. It only happened if I installed a newer version than before.
Ilikemyprivacy wrote: Thu Aug 28, 2025 6:39 pm I reinstalled 1.9.3 and the problem doesn't exist if I install the same version I had before. It only happened if I installed a newer version than before.
you can reinstall 1.9.2 and 1.9.3
Ilikemyprivacy
[/quote]
[/quote]
Do you have 1.9.2? I only see 1.9.3 https://www.xnview.com/en/xnview-mp/
