Delete original not working when converting multipage file
CBATnet
Post by CBATnet »
I've been trying to use XnConvert with a hot folder to automatically convert TIF files to PDF files as they are placed in the folder, and delete the original TIF from that hot folder.
So far this seems to be working, however any multi-page TIF files will convert to multi-page PDF files, but the multi-page TIF original will NOT be deleted. Is there some way I can get this to also delete multi-page originals? This is XnConvert 1.102.0 in Windows. Thanks.
CBATnet
Re: Delete original not working when converting multipage file
Post by CBATnet »
As an update, I also tried the same process with XnView, and received the same result.
CBATnet
Post by CBATnet »
Just following-up on this. Does anyone know if this is normal behavior or something that can be adjusted?
CBATnet
Post by CBATnet »
Great news, thanks Pierre! I look forward to the release of the XnConvert update!
CBATnet
Post by CBATnet »
Confirmed, multi-page TIFs are being converted to multi-page PDFs, and the original TIFs are being deleted after convert as expected.
Thanks very much Pierre!
