1.8.4 Sidecars / companion files are no longer hidden
Flyk3
Post by Flyk3 »
I have updated from version 1.8.3 to 1.8.5 and since then the .xmp sidecars / companion files are suddenly displayed, although I have switched off the corresponding option. The error also exists in versions 1.8.6 and 1.8.4.
Enclosed are two copyright-free video files with the corresponding .xmp files for testing.
The option can be found under File list -> Companion files -> Show companion files.
Greetings
2025-02-16 1.8.4 Sidecars companion files are no longer hidden.7z
(43.15 KiB) Downloaded 232 times
Re: 1.8.4 Sidecars / companion files are no longer hidden
Flyk3
Post by Flyk3 »
Sorry for the very late reply.
The bug is fixed. Thank you! :D
