Slideshow settings when I right click on a folder to "start slideshow"
Sun Yat-Sen
Post by Sun Yat-Sen »
If I start a slideshow using the slideshow icon at the top of the interface, it opens up a settings screen, and uses those settings when I start the slideshow.
When I then later right click on a folder to "start slideshow," the slideshow starts instead on default settings, and does not present me with an opportunity to change those settings.
Is there a way for me to set the settings that should be used for right-click "start slideshow" slideshows?
Re: Slideshow settings when I right click on a folder to "start slideshow"
This problem is supposed to be fixed in XnView MP 1.8.8. Please check and confirm the bug fix here.
Sun Yat-Sen
It is fixed! Thank you.
